Hi, my RV has these sensors on the tank: https://www.recpro.com/rv-water-tank-adhesive-sensors/ They stick to the outside of the tank so they must be some kind of capacitance sensor.
Unfortunately the display board does not provide much precision, it has LEDs for Full, 2/3, 1/3, and Empty. I'd like to rig up a much more precise system, I assume I'll have to install a new sensor and display, but I am wondering what kind of signal comes out of these sensors? Maybe I could just tap into that? All 3 sensors connect to the display board using only two wires, which is interesting.
Occasionally on the display board I'll see one LED starting to light while the previous one starts to flicker. So maybe this is a linear signal that comes from these three sensors, and the control board interprets it as 1/3, 2/3, etc?
Thoughts on this these sensors work? I probably won't hurt the system by measuring voltage from each wire to ground, right?
