I am trying to find a cheap solution to measure amps at half-hour signals from a 230V, 50hz supply.
I want to do this for energy monitoring on different buildings and want non-electricians to do the visits so a CT clamp solution is required.
I want to use off-the-shelf components because I want the system to be durable and simple to use.
No requirment to measure the voltage as accuracy s not important ( +-10% is fine)
The all-in-one offerings are very expensive such as the HOBO monitor with their own CTs, or the Tinytag offering. these are expensive because they need CTs with built-in ACD chip to convert the analogue CT output to a digital voltage signal to be read by the logger. they also have lots of functionality I dont require.
Im wondering if the below solution might work - essentially cheep split core CTs connected to standard pulse power meters and a pulse logger
3 * 5V output CTs (approx £30 each) https://uk.rs-online.com/web/p/current-transformers/5330637
3 * single phase energy meter with a voltage pulse output (approx £80) https://uk.rs-online.com/web/p/energy-meters/1242437
1* pulse reading data logger (approx £100) - https://docs.rs-online.com/ffbf/A700000008456228.pdf
This solution comes out as £300 whereas most other solutions are £600 plus.
However, power meters have an input for line voltage which is not satisfied - my main questions are
1. Can you set a power meter to assume a voltage of say 230V and not need to measure it?
2. Could I connect a constant DC or AC voltage source (low voltage) to the voltage inputs and then manipulate the results afterwards to give actual power assuming 230V
3. Is there any other way to get around this issue?
4. are there any other ways to achieve what im trying to achieve without paying for the all-in-one solutions? bearing in mind size and accuracy are not of importance
thanks for reading!
thanks for reading!
