I am trying to draw up a circuit diagram for a electric window opener.
There will be two limit switches connected to a motor controller so that the motor will stop when the limit switches (one for window position position and one for the closed position) are trggered..
The controller has the limit switch terminals built-in:
https://m.aliexpress.com/item/3256801637729742.html
Which type of limit switch should I get that will work with this controller to my needs? The fwd and rev buttons will be operating in toggle mode to open and close the window. When the open limit is triggered, the motor will stop. The user s has the ability to close the window by pressing the close button from the remote and vice versa.
Does that means that I just need two 2p limit switches connected to the controller?
