Help needed in understanding the current sense circuit using dual PNP transistor ?
mishra87
Joined Jan 17, 2016
1,036
Hey @all
Can anyone explain me how this circuit works ?
How can we calculate Vout in term of load current (I_Load) value.
We can assume Power Supply =12V and Rsense = 500mOhm, RL=500mA etc for analysis.
Any help will highly appreciated.
Thanks in Advance !
34,428
That circuit is incorrect (as my simulation showed).
(Where did you find it?)
An increase in current lowers Q1b's emitter voltage which turns it off.
If you interchange the power supply with the load so the current goes in the opposite direction through Rsense, and select appropriate resistor values, then it will work (sim results below):
(I leave the selection of the resistor values to the TS).
Q1a is connected as a diode to essentially cancel the Vbe of Q1b.
The sense resistor voltage drop lowers the node 1 voltage from Q1a, which generates a voltage across R2 to cause a current through Q1b and thus a voltage at Vout.
panic mode
Joined Oct 10, 2011
2,749
the equations in article do not match the circuit. it looks like circuit is drawn incorrectly - PSU and Load have switched places.
