Dear Experts,
I have a specific need to improvise a circuit for sparking a Spark Plug (a Vehicle Spark Plug) outside the vehicle set up. On a table top.
So I searched and came across this circuit design where it requires one to connect a battery to Ignition Coil thru a ballast resistor and the output of ignition coil connects to the spark plug. (Image attached)
I didnt use the distributor cam etc., but just used a contactor to break open the primary coil voltage from battery to see if the plug sparks.
It does spark, but the issue is that the spark is too feeble. Visible but feeble. Also, its not repetitive.
Now I am using standard automobile components so I don't wanna doubt them.
My questions:
1) Is this circuit, as it is, implemented in an automobile? Or its only an indicative one, with other spark intensity enhancing features added in real world design.
2) The secondary side of coil would require to spark the plug every fraction of second, given the speed of movement of piston etc. When I am repeatedly making and breaking the contacts, the spark seems to get more and more feeble and fails very frequently. So what is it that I am missing.
3) In the circuit it shows that the return of both Primary and Secondary side is connected to the return of Battery. Is it right? Doesnt it mix up the isolation between the two sides of the induction coil?
My aim is to get a healthy spark that is capable of igniting a predominantly methane gas mixture, under controlled conditions.
Looking forward to some insights on this.
Thanks in advance and regards,
Rahul
My questions:
Rahul
