Can i get assistance on this code for PIC16F1823 done in MPLAB xIDE. The structure is such, the PIC counts the number of bits going trough the input signal line via the capture mode on pin RC5. If the PIC counts up to a certain number eg 240 bits, then the PIC gives a high signal on pin RA5. this signal is used to switch the mutex which then diverts the signal to a different route. So 240 bits pass on one route and the rest of the bits will pass on the second route when the mutex is switched on. See the attached file .
The issue is that the output I am getting is very erratic with the signal being switched inconsistently between the two lines/routes. I have tried different methods by changing the code to no success. Any form of assistance will be highly appreciated
C:
#include <xc.h>
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <stdint.h>
/**CONFIGURATION BITS**/
// PIC16F1823 Configuration Bit Settings
// 'C' source line config statements
// CONFIG1
// CONFIG1
#pragma config FOSC = INTOSC // Oscillator Selection (INTOSC oscillator: I/O function on CLKIN pin)
#pragma config WDTE = OFF // Watchdog Timer Enable (WDT enabled)
#pragma config PWRTE = OFF // Power-up Timer Enable (PWRT disabled)
#pragma config MCLRE = ON // MCLR Pin Function Select (MCLR/VPP pin function is MCLR)
#pragma config CP = OFF // Flash Program Memory Code Protection (Program memory code protection is disabled)
#pragma config CPD = OFF // Data Memory Code Protection (Data memory code protection is disabled)
#pragma config BOREN = OFF // Brown-out Reset Enable (Brown-out Reset enabled)
#pragma config CLKOUTEN = OFF // Clock Out Enable (CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin)
#pragma config IESO = ON // Internal/External Switchover (Internal/External Switchover mode is enabled)
#pragma config FCMEN = ON // Fail-Safe Clock Monitor Enable (Fail-Safe Clock Monitor is enabled)
// CONFIG2
#pragma config WRT = OFF // Flash Memory Self-Write Protection (Write protection off)
#pragma config PLLEN = ON // PLL Enable (4x PLL enabled)
#pragma config STVREN = ON // Stack Overflow/Underflow Reset Enable (Stack Overflow or Underflow will cause a Reset)
#pragma config BORV = LO // Brown-out Reset Voltage Selection (Brown-out Reset Voltage (Vbor), low trip point selected.)
#pragma config LVP = OFF // Low-Voltage Programming Enable (High-voltage on MCLR/VPP must be used for programming)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
//FOSC
#define _XTAL_FREQ 16000000 //16MHz // Fosc frequency for _delay() library
////*****END OF CONFIGURATION BITS******///
//WE LL USE TIMER INTERRUPT
#define switch RA5
unsigned int Count = 0;
long bit_count = 0;
//HARD CODED INTEGER VALUE
//DATA
//int data = 30;
* NOTE: PRIOR CALCULATION NEEDED
* formula ===>
* switch_delay = data*1000000/800000 (in uS)
* this will be the needed delay time for switching the neopixels
//set this delay constants according to your needs
int Bit_number = 240 ; //place the number of bits to pass in the first strip here the rest will pass in the second strip
//void splitter ();
void capture_ISR()
if ( CCP1IF == 1) //External Interrupt detected
bit_count++; //increase bits count by 1on receiving a falling edge signal
TMR0 = 50; //RESET TIMER 0 REGISTER TO 50
else{
//do nothing and just return
void main(void) {
//clock source and frequency setting
// OSCCON |=0b01111000; //16MHZ INTERNAL CLOCK
//port
TRISCbits.TRISC5 = 1; // set pin as INPUTt
APFCON = 0b00000001;
CCP1CON = 0b00000101;//SET CAPTURE COMPARE WITH RISING EDGE INTERRUPT
PORTC=0x00; //clear port a data
// TURN TIMER 1 ON
T1CON = 0b00110101;
// PG 192 DATASHEET
CCP1IF = 0;//INTERRUPT FLAG FOR CCP1 SET TO ZERO/CLEARED
// TMR0=0; //TMR0 Initiation
// T0CS=0; //Choosing to work with internal clk
// T0SE=0; //Reacting on Low2High edge
// PSA=0; //Choosing to work with a Prescaler
// PS0=1;
// PS1=1; //Prescaler value divides 256
// PS2=1;
//timer 0 setup for 25uS
OPTION_REG = 0b01000000; //SEE PG 164
TMR0IE = 1;
TMR0IF = 0;
TMR0 = 50; //156 or 50
INTCON= 0b11000000;//enable global interrupt and peripheral interrupt
PIE1 = 0b00000100; //ENBLE CCP INTERRUPT AND TIMER 1 INTERRUPT
PORTA=0x00; //clear port a data
TRISAbits.TRISA5 = 0; // set pin as output
PORTA = 0x00;
while(1)
if(bit_count >= Bit_number)
PORTA = 0xFF;
else
PORTA = 0x00;
if(TMR0IF)
{//Stays here 256 times and then T0IF=1
TMR0IF=0; //Resetting the overflow flag
TMR0 = 50;
//IF THIS TIMER RUNS TO THE END THEN 50uS have elapsed and we reset the counter bit
bit_count = 0; //reset the bit counter after 50uS downtime
return;
