I have a Line Lock Solenoid (normally open) that requires 12v to activate. But the manufacturer only recommends to use for 60 seconds at a time, I've learned that you can hit a solenoid with 12v to pull it closed but then you can lower the voltage to say 5v to hold it closed (I will do testing to see what the actual hold voltage is). Greatly increasing the run time before it gets too hot. This is going in a car. The simpler the better
I have contacted the manufacturer and apparently they have no data sheet for this solenoid...
Part Number
AF49-4075
So my question is, How do I design a step down circuit that hits it with 12v initially but then drops the voltage afterwards for continuous use until turned off?
Or is there an off the shelf option that I cant find. I've only found step down circuits that are always at the lower voltage :/
Also this would be safe to have 1 circuit feeding 2 solenoids? I'm planning to wire it as 12v source > on\off switch > this step down circuit > both solenoids > individually grounded to the chassis. If need be I;m happy to make 2 circuits
I would also like to add I'm not fussed about wasted energy or making sure it runs *perfectly*. The solenoid doesnt have to stop at certain points. It just needs to stay fully closed.
Thank you in advance.
Part Number
AF49-4075
