All they are telling you as an example you can have 0 to 101 kilopascals = 0.5 to 4.5 volts or you can have 101 kilopascals to 0.0 kilopascals = 0.0 to 4.5 volts.
Note on the chart the reference is atmosphere. There is no such thing as negative pressure. It's about a point of reference. So what we get is:
Standard sea-level pressure, by definition, equals 760 mm (29.92 inches) of mercury, 14.70 pounds per square inch, 1,013.25 × 103 dynes per square centimeter, 1,013.25 millibars, one standard atmosphere, or 101.325 kilopascals.
So is we figure atmospheric pressure = 101.325 kilopascals and anything below that is below atmospheric pressure. We could say a vacuum but it is still above zero. Atmospheric pressure is constantly changing along with the weather or altitude above mean sea level. There is no negative pressure since we start with 101 kilopascals. Once we get down to 0.0 there is no lower.
All the highlighted line is telling you is the sensor can be scaled in either direction with an output either proportional or inversely proportional to pressure.
Ron
Ron
i'am trying to read -95kpaWhat is the part number for the sensor? We want to read the entire data.
trying to read -95KPAWhat is the part number for the sensor? We want to read the entire data.
i mean the reverse thing is it customized by the manufactureAll they are telling you as an example you can have 0 to 101 kilopascals = 0.5 to 4.5 volts or you can have 101 kilopascals to 0.0 kilopascals = 0.0 to 4.5 volts.
Ron
You posted a chart and that's all. Less a part number specific data sheet I doubt anyone will be able to tell you much about the sensor. I can tell you that the output can apparently be scaled to be proportional or inversely proportional to sensed pressure. That is what the line on top tells you.i mean the reverse thing is it customized by the manufacture
https://www.micros.com.pl/mediaserver/CZ_XGZP6867a010kpg_0001.pdfYou posted a chart and that's all. Less a part number specific data sheet I doubt anyone will be able to tell you much about the sensor. I can tell you that the output can apparently be scaled to be proportional or inversely proportional to sensed pressure. That is what the line on top tells you.
You can't just say -95 kilopascals. You need a point of reference. I assume -95 kilopascals referenced to atmosphere since you don't mention absolute pressure. Note on the chart where they mention atmospheric pressure? The charts cover several gauges, you likely want the 0 to 100 kilopascal one or referenced to atmosphere 0 to -100. Less a data sheet I have no idea as to how the output can be scaled. Less a link to manufacturer and data sheet nothing else can be said.
I also cannot find the part?
Ron
sorry for the late response I'm trying to measure that pressure (-95kpa) using an Arduino card and the software LabVIEW m going to use the convert equation y=xm+bWell alright now we have a datasheet. The way this is worded:
" (Output can be calibrated to reverse line with pressure, e.g.-100~0kPa correspond with 4.5~0.5V) "
What I believe since there is no mention of it is that if reading the output with a uC (Micro-Controller) the display can be calibrated using a software solution.
You want to read -95 kilopascals based on atmospheric pressure so you want the part number XGZP6867A100KPGN which measures from atmosphere 0 down to -100 kilopascals. That would be my choice since you are not interested in pressure above the atmosphere. The datasheet mentions " Output Signal(A: Analog(0.5-4.5V) D: I2C) " but I see no information for the I2C output version? Matters not if you just want the analog output. It's an 8-pin package but only 3 pins are used. WE have Vcc, GND, and Signal out. The datasheet is pretty basic.
How were you planning to measure the output and convert the analog signal to units of measure in kilopascals?
Ron
// number of analog samples to take per reading
#define NUM_SAMPLES 10
int sum = 0; // sum of samples taken
unsigned char sample_count = 0; // current sample number
float voltage = 0.0; // calculated voltage
float pressureValue = 0.0;
void setup()
Serial.begin(9600);
void loop()
// take a number of analog samples and add them up
while (sample_count < NUM_SAMPLES) {
sum += analogRead(A0);
sample_count++;
delay(10);
// calculate the voltage
// use 5.0 for a 5.0V ADC reference voltage
// 4.950V is the calibrated reference voltage
voltage = ((float)sum / (float)NUM_SAMPLES * 4.950) / 1024.0;
//Map the Analog In Value
pressureValue = map(voltage, 0.5, 4.5, -100, 0);
//Serial.print(voltage);
Serial.println(" Volts");
Serial.println("");
Serial.print(pressureValue);
Serial.println(" Kilopascals");
sample_count = 0;
sum = 0;
delay(500);
int sensorPin = A0; // Select Sensor Input Pin
int sensorValue = 0;
//float sensorPin = 0.0; // Calculated Sensor Value
float pressureValue = 0.0; // Calculated Sensor Value
void setup()
Serial.begin(9600);
void loop()
sample_count++;
delay(10);
pressureValue = map(analogRead(0), 102, 922, -100, 0);
Serial.print (pressureValue);
Serial.println (" Kilopascals"); //Line Feed
Serial.println(); //Blank Line
sample_count = 0;
sum = 0;
pressureValue = 0;
delay(500);
than you sooo much mr ron god bless youSince I plan to be out of town for the holiday weekend here in the US I will leave you with a basic code sample written using an Arduino Uno Rev 3. Both samples use the map function.
The short version I found.Code:// number of analog samples to take per reading #define NUM_SAMPLES 10 int sum = 0; // sum of samples taken unsigned char sample_count = 0; // current sample number float voltage = 0.0; // calculated voltage float pressureValue = 0.0; void setup() { Serial.begin(9600); } void loop() { // take a number of analog samples and add them up while (sample_count < NUM_SAMPLES) { sum += analogRead(A0); sample_count++; delay(10); } // calculate the voltage // use 5.0 for a 5.0V ADC reference voltage // 4.950V is the calibrated reference voltage voltage = ((float)sum / (float)NUM_SAMPLES * 4.950) / 1024.0; //Map the Analog In Value pressureValue = map(voltage, 0.5, 4.5, -100, 0); //Serial.print(voltage); Serial.print(voltage); Serial.println(" Volts"); Serial.println(""); Serial.print(pressureValue); Serial.println(" Kilopascals"); sample_count = 0; sum = 0; delay(500); }
Code:// number of analog samples to take per reading #define NUM_SAMPLES 10 int sum = 0; // sum of samples taken int sensorPin = A0; // Select Sensor Input Pin int sensorValue = 0; unsigned char sample_count = 0; // current sample number //float sensorPin = 0.0; // Calculated Sensor Value float pressureValue = 0.0; // Calculated Sensor Value void setup() { Serial.begin(9600); } void loop() { // take a number of analog samples and add them up while (sample_count < NUM_SAMPLES) { sum += analogRead(A0); sample_count++; delay(10); } //Map the Analog In Value pressureValue = map(analogRead(0), 102, 922, -100, 0); Serial.print (pressureValue); Serial.println (" Kilopascals"); //Line Feed Serial.println(); //Blank Line sample_count = 0; sum = 0; pressureValue = 0; delay(500); }
Ron
by Jeff Child
by Robert Keim
by Jake Hertz
