P-Channel MOSFET always on
AAnkur
Joined Jan 29, 2015
8
Hello
Hello
I am using a MOSFET driver circuit with SI2303 as p-channel mosfet and SI2302 as n-channel mosfet.
I have given control signal (of 5V) on the gate of n-channel mosfet to turn-on and off the p-channel mosfet.
However, the p-channel mosfet is not getting off and I am constantly finding voltage on Output (marked as Point-A).
Please let me know what is the problem in this circuit.
DickCappels
Joined Aug 21, 2008
10,187
Even when a MOSFET is not driven on there is some leakage current between the source and drain. Do you have a load from the drain of the P-channel to ground? If not, you might want to add a load or dummy load resistor to ground and measure again.
The drain current should be only a few microamps - enough to show up on a DVM. A 1k resistor from the P-channel drain to ground should show zero to a few millivolts across the resistor
LowQCab
Joined Nov 6, 2012
4,075
A 100k Resistor on the P-FET might be too much Resistance to completely turn it off,
it will certainly make it Switch slowly.
Are You trying to conserve Battery-Power ?
Try making the Resistors ~10-times smaller.
