Over the years I have collected a few 18650 cells and I am trying to find a use for them..I was thinking about build a DIY power bank to charge my cell phone but I am open for ideas here ..
Thanks
Jay
Thanks
Jay
As near as I can tell, Dave, you have one bad (below cutoff threshold, usually 3.0V) cell and the protection circuit is cutting it out so it won't even charge. Best way to charge these is with hobby chargers that charge the cells individually (with a "balance" charge cable). But it necessarily bypasses the protection circuit for charging. Still, with multi-cell Li-Ion/LiPoly packs, it's the best way to charge.Just what I am trying to do here, but cant seem to get any output?
http://forum.allaboutcircuits.com/threads/18650-battery-protection-pcbs.122582/
Wait what is the cell capacity per cell again??All very well, i have three 3.7V 9900mAh cells, but i cant charge the buggers with this protection pcb....
IN 18650 SIZE!! oh my... who ever sold them slapped an extra zero at the end it seems man... this size cant hold more than 3200 if even that for the most expensive cell....9900maH, i can charge them up on my atx psu no problem, but this poxy pcb won't work, i have ordered a different one.
Hence my reply ..So pcb might be good and cells bad then..IN 18650 SIZE!! oh my... who ever sold them slapped an extra zero at the end it seems man... this size cant hold more than 3200 if even that for the most expensive cell....
that is surely dodgy, dave!
Did you do the real test about the 9900 mAh?
There is the larger 32650 for more mAh. Usually the charger output is 5 V. The charging chip inside the phone brings it down to the 3.7 V. So you need a circuit to bring the external battery up to 5 V.Over the years I have collected a few 18650 cells and I am trying to find a use for them..I was thinking about build a DIY power bank to charge my cell phone but I am open for ideas here ..
Thanks
Jay
Interesting! 9900 mAh at what current level I wonder. You wouldn't have a data sheet for the battery would you?
I really dont think even 1 micro amp could get that much... but i am not an expert...... niether is whoever sold these...Interesting! 9900 mAh at what current level I wonder. You wouldn't have a data sheet for the battery would you?
Rather than hack this thread, continue here...Interesting! 9900 mAh at what current level I wonder. You wouldn't have a data sheet for the battery would you?
by Dale Wilson
