I'm sure knows who birthed invention by way of necessity.
I am very adept at building and designing wearables and pretty much anything to fit a situation. what I have very little knowledge of is peltier modules and the power necessities behind them I've done extensive reading but it's a little beyond my level. I'm very adept at soldering and connecting all manner of electronics but I wonder if anyone could help me figure out the most efficient peltier modules to get if I have a 40 volt battery to run my setup I'm guessing only two peltier modules would be necessary and the rest of the power would go to fans for cool air delivery and massive heat sink dissipation. If someone could tell me what modules I should get and how much power I should devote to fans afterwards if I'm using this 40 volt battery I can make something to get me through the hot midsummer months without heat headaches everyday. I fully understand the need for venting and placement but again the proper modules to use and how much power I should devote to fans eludes me. I understand that I won't be making a Mr freeze suit anytime soon but if I can drop the temperature hitting my neck by just a few degrees the world will be peachy keen.
