Hi everyone,
I would like some help in fixing a Hotplate+Stirrer which has slowly developed a fault with the temperature control. Over time the variable resistor that controls the heat and the range has become more and more compressed. As it is ATM the heat is little better than on and off, slightly warm to boiling. This has slowly increased over time to it's current state.
BTW two pictures are opposite sides of the circuit board controlling the heat to the hotplate and they have been rotated and flipped so that the connections are all in the same location ie connectors etc. C3 which is the large capacitor on the upper left next to the LED which is 0.22 uF 250V / 275V. The 6 pin IC is labelled with MOC3023 443Q and looks like a fairchild component. The 8 pin IC you can see in the picture.
My question is do you think that it is feasible to repair this? I have some basic electronics knowledge, a variable temperature soldering iron and a Tenma 72-10415 Multimeter which is fairly accurate at around £120.
Carl
Carl
