Yo!
I have a garage door that runs of a controller unit and on the controller box i have a push button to open/close the door (besides the remote with wich it comes).
I also have a Legrand home smart system installed - This basically connects to my wi-fi and i am able to control various items over an app such as lights and sockets.
Now:
I have a switching module as received from Legrand. This works similar as the connected light switches, it just does not have a physical switch to touch/push, in other words, only the internal wifi connected contactor. This module connects me to the app system, but what i am looking for is a integration for this unit to the garage push/tap switch.
The only option i see is to install a timed relay (in order to "tap" the switch). The problem with this is that the app will tell me the door is either open/close (or rather the contactor), but the actual garage door switch is a contacting signal sending type, meaning you tap the button only in order to open or close - But on the app it will only show the open/closed position of the contactor.
Any recommendations for a solution?
Cheers
J
Now:
Cheers
J
