I have a project I'm working on that uses a potentiometer turned via linkage mechanism to capture the movement of a swivel mechanism. Imagine a 2 foot flat bar with a pivot point in the middle that swings a about 45 degrees in either direction. I'd like to convert it to use a hall effect sensor but I'm unsure of what type of hall effect sensor to use and how to mount it and a magnet to capture the motion. Pretty sure I need a linear analog Hall sensor, it'll be replacing a pot that runs off 5 volts.
