I am creating a project of temperature indication using thermistor with pic16f877A. and 4 channel 7 segment Display.
The problem I am facing is Using timer to read adc values and converting to Celcius makes my 4 channel 7 segment display to blink after every 2 Seconds. At ln0 line the display starts to blink.If I use to print ADC values then it is not a problem but As soon as I do the conversion from adc to Celcius it starts to blink.
Attaching my code file for reference.
Mod edit: code tags - JohnInTX
C:
* File: Rectal.c
* Author: admin
* Created on 15 March, 2022, 10:36 AM
#include"config.h"
#include<math.h>
#include<stdio.h>
//Values in the datasheet
#define RT0 10000
#define B 3977
#define VCC 5.03
#define R 10000
float RT01, VR0, ln0, TX0, T0, VRT0,T_SUM0, diff;
//Defining pins
#define Rect PORTAbits.RA0
#define Skin PORTAbits.RA1
#define b PORTBbits.RB5
#define a PORTBbits.RB4
#define f PORTBbits.RB3
#define g PORTBbits.RB2
#define d PORTBbits.RB1
#define e PORTBbits.RB0
#define c PORTDbits.RD7
#define d4 PORTDbits.RD6
#define d3 PORTDbits.RD5
#define d2 PORTDbits.RD4
#define d1 PORTCbits.RC7
#define set PORTDbits.RD1 //C2-d1
#define ret PORTCbits.RC2 //C3-d0
#define down PORTCbits.RC3//d0-c3
#define up PORTDbits.RD0//d1-c2
int j,k,l,m,n,o ,T_Approx=370;
int adc,i=0;
int count=0,s=0;
void zero() {
a=0;
b=0;
c=0;
d=0;
e=0;
f=0;
g=1;
void one() {
a=1;
b=0;
c=0;
d=1;
e=1;
f=1;
g=1;
void two(){
a=0;
b=0;
c=1;
d=0;
e=0;
f=1;
g=0;
void three(){
a=0;
b=0;
c=0;
d=0;
e=1;
f=1;
g=0;
void four() {
a=1;
b=0;
c=0;
d=1;
e=1;
f=0;
g=0;
void five(){
a=0;
b=1;
c=0;
d=0;
e=1;
f=0;
g=0;
void six(){
a=0;
b=1;
c=0;
d=0;
e=0;
f=0;
g=0;
void seven(){
a=0;
b=0;
c=0;
d=1;
e=1;
f=1;
g=1;
void eight(){
a=0;
b=0;
c=0;
d=0;
e=0;
f=0;
g=0;
void nine(){ //the 7-segment led display 9
a=0;
b=0;
c=0;
d=0;
e=1;
f=0;
g=0;
void clearLEDs(){ //clear the 7-segment display screen
a=1;
b=1;
c=1;
d=1;
e=1;
f=1;
g=1;
void pickDigit(int x){ //light up a 7-segment display
//The 7-segment LED display is a common-cathode one. So also use digitalWrite to set d1 as high and the LED will go out
d1=1;
d2=1;
d3=1;
d4=1;
switch(x)
case 0:
d1=0;//Light d1 up
break;
case 1:
d2=0; //Light d2 up
break;
case 2:
d3=0; //Light d3 up
break;
default:
d4=0; //Light d4 up
break;
void pickNumber(int x){
switch(x)
default:
zero();
break;
case 1:
one();
break;
case 2:
two();
break;
case 3:
three();
break;
case 4:
four();
break;
case 5:
five();
break;
case 6:
six();
break;
case 7:
seven();
break;
case 8:
eight();
break;
case 9:
nine();
break;
void ADC_Initialize(){
ADCON0 = 0b10000001; //ADC ON and Fosc/16 is selected
ADCON1 = 0b11000000; // Internal reference voltage is selected
unsigned int ADC_Read(unsigned char channel)
ADCON0 &= 0x11000101; //Clearing the Channel Selection Bits
ADCON0 |= channel<<3; //Setting the required Bits
//__delay_ms(2); //Acquisition time to charge hold capacitor
ADCON0bits.GO_DONE = 1; //Initializes A/D Conversion
while(ADCON0bits.GO_DONE); //Wait for A/D Conversion to complete
return ((ADRESH<<8)+ADRESL); //Returns Result
void __interrupt() my_ISR(){
if(INTCONbits.TMR0IF==1){
count++;
TMR0=11;//11
T_SUM0=0;
INTCONbits.TMR0IF=0;
if(count==5959){count=0;s++;}// PORTD=~PORTD;5959
if(s==2){s=0;
// INTCONbits.TMR0IE=0;
for(i=0;i<3;i++){
VRT0 = (ADC_Read(0)); //Acquisition analog value of VRT
VRT0 = ((VCC / 1023.00) * VRT0); //Conversion to voltage
VR0 = VCC - VRT0;
RT01 = VRT0 / (VR0 / R);//Resistance of RT
ln0 = log(RT01 / RT0);
TX0 = (1 / ((ln0/B) + (1 / T0)) ); //Temperature from thermistor
TX0 = TX0 - 273.15;//Conversion to Celsius
T_SUM0+= TX0;
T_SUM0 =T_SUM0*10;
T_Approx = T_SUM0/(3);
//INTCONbits.TMR0IE=1;
void main(void) {
TRISDbits.TRISD1 = 1;
TRISDbits.TRISD0 = 1;
TRISCbits.TRISC3 = 1;
TRISCbits.TRISC2 = 1;
TRISAbits.TRISA0 = 1; // defining analog pins
TRISAbits.TRISA1 = 1;
TRISBbits.TRISB0 = 0;// defining digital pins
TRISBbits.TRISB3 = 0;
TRISBbits.TRISB1 = 0;
TRISBbits.TRISB2 = 0;
TRISDbits.TRISD6 = 0;
TRISDbits.TRISD5 = 0;
TRISDbits.TRISD7 = 0;
TRISDbits.TRISD4 = 0;
TRISCbits.TRISC7 = 0;
TRISBbits.TRISB5 = 0;
TRISBbits.TRISB4 = 0;
TRISCbits.TRISC6 = 0;
ADC_Initialize();
T0 =25+ 273.15;
INTCONbits.GIE=1;
INTCONbits.PEIE=1;
ei();
OPTION_REGbits.T0CS=0;
OPTION_REGbits.T0SE=0;
OPTION_REGbits.PSA=0;
OPTION_REGbits.PS2=0;
OPTION_REGbits.PS1=0;
OPTION_REGbits.PS0=1;
//TMR0=11;
j = T_Approx/10;
k=j/10;
l=k/10;
while(1){
clearLEDs();//clear the 7-segment display screen
pickDigit(0);//Light up 7-segment display d4
pickNumber((T_Approx/1000)%10);//Get the value of single digit
__delay_ms(0.5);//delay 5ms
pickDigit(1);//Light up 7-segment display d3
pickNumber((T_Approx/100)%10);//get the value of ten
pickDigit(2);//Light up 7-segment display d2
pickNumber((T_Approx/10)%10);// get the value of hundred
pickDigit(3);//Light up 7-segment display d1
pickNumber( T_Approx%10);// get the value of thousand
if(!set){
__delay_ms(200);
if(set){m=1;
// T_Approx = ((1.8*T_Approx) + 32);
//j = T_Approx/10;
//k=j/10;
// l=k/10;
