Audio Frequency signal
Dadu@
Joined Feb 4, 2022
155
I am trying to understand the use of audio frequencies. Frequency is measured in Hertz (Hz), I see that the graph of the signals drawn in one axis shows the frequency and the other shows the time. I don't understand what is the use of measuring signal by frequency.
I see that microphone converts audio signal into voltage signal. The processor takes the voltage signal and processes it. and a display device shows the frequency of the signal. I do not understand why we have to measure the frequency, what are its benefits?
Papabravo
Joined Feb 24, 2006
21,225
Convenience
Ya’akov
Joined Jan 27, 2019
9,148
Audio signals are characterized by their frequency. The Fourier Transform decomposes an audio signal into its component frequencies which when added together comprise the signal we hear. Since frequency is the foundation of audio and radio signals it makes sense to use that instead of period or wavelength, which are sometimes useful, because to use the information in those forms you’d almost always find yourself converting to frequency.
In some areas, like light, wavelength is used because it is the most generally useful way to characterize it for practical use.
Papabravo
Joined Feb 24, 2006
21,225
To sum it up. Convenience.
Audioguru again
Joined Oct 21, 2019
6,690
The frequency of a sound is the musical "pitch" plus harmonic frequencies from very low to very high.
Most humans can hear from 20Hz (20 waves per second) to 20kHz (20 thousand waves per second).
Home electricity is 50Hz in some countries or is 60Hz in other countries.
MrSalts
Joined Apr 2, 2020
2,767
Look at the back of your appliances, the plate near the cord uses the Hz symbol. Look at the face of your radio dial, it uses the kHz (AM) and/or MHz (FM). Your WiFi router says 5GHz, your PC says 2.4GHz. The update frequency on your display is 120Hz.
Do you really have such a general question like, "what are the benefits" when you see the important unit if measure on devices around you? Or do you have a more specific question?
30,802
When you strike a bell you hear frequency, not time.
When the lady sings your ear responds to frequency, not time.
Audioguru again
Joined Oct 21, 2019
6,690
Nobody can hear radio frequencies. Dadu asked about audio frequencies.
My oscilloscope and my multimeter show audio frequency numbers and my hearing can detect some harmonics.
Ya’akov
Joined Jan 27, 2019
9,148
When an orchestra tunes up their reference is a A. In particular the A that is 400Hz.
We call it a “440 A”. We could call it a “779.545mm@20°C A”, or a “2.2727ms A” but somehow it seems that the frequency is much more cogent. A tuning fork can tell you if you have the note right because it has a resonant frequency that matches. I think using a ruler or clock would be harder.
Of course this is silly but it is just more practical evidence for using frequency which flows from the nature of oscillating systems.
Ian0
Joined Aug 7, 2020
9,809
That would just be graph of y=1/x
I've seen voltage vs. time, voltage vs. frequency but never time vs. frequency
