The proper bands for data transmission are the 915MHz (LoRa) and 2.4Ghz (NRF24L01/NRF24L01+). For LoRa, you are probably going to want an ESP32-based board with the LoRa module in place. For the NRF24L01 you buy a module and there are libraries for Arduino compatibles.§ 15.231 Periodic operation in the band 40.66-40.70 MHz and above 70 MHz.
(a) The provisions of this section are restricted to periodic operation within the band 40.66-40.70 MHz and above 70 MHz. Except as shown in paragraph (e) of this section, the intentional radiator is restricted to the transmission of a control signal such as those used with alarm systems, door openers, remote switches, etc. Continuous transmissions, voice, video and the radio control of toys are not permitted. Data is permitted to be sent with a control signal. The following conditions shall be met to comply with the provisions for this periodic operation:…
ThanksHello,
of course you can, but you have to handle signal modulation and encrypt send data on your own.
Best Regards
Thank you Yaakov.in the US, the radio service in the 433MHz band in pretty narrowly defined. In particular, the only data you are permitted to send is along with a remote control signal. It is not the right band for data transmissions.
Operation on unauthorized bands is both illegal and unnecessary. The options I provided are legal and better anyway.I suggest using the 315 MHz band instead. With that little transmitter for na short distance and a short time it wi not get any attention or cause interference. Aso,what sort of data do you intend to send?? Radio signals are not at all private, you know.
Which is authorized for remote control not data. Why not use allocations that permit data transmission with hardware designed to do it?315 is a key-fob band.
Hello,in the US, the radio service in the 433MHz band in pretty narrowly defined. In particular, the only data you are permitted to send is along with a remote control signal. It is not the right band for data transmissions.
Oh, I understood that. I hope you didn't take my post as chastisement, it wasn't meant that way. The regulatory aspect is often overlooked and people seem to assume if they can buy something that transmits it means it's legal to use.Hello,
I only respond to technical possibility, I didn't know law limitations in USA.
Best Regards
Thanks.I suggest using the 315 MHz band instead. With that little transmitter for na short distance and a short time it wi not get any attention or cause interference. Aso,what sort of data do you intend to send?? Radio signals are not at all private, you know.
Thank you.Getting back to the original question. Those modules do not, by themselves, send data. They only turn the carrier on and off. Turning this into data transmission is up to the user.
Bob
(Please do not interpret this as a political statement)Those modules do not, by themselves, send data. They only the carrier on and off.
