Hi there. Not sure exactly what section this fits into here but I'm trying to identify what is reporting current draw on my Dell motherboard. Specifically a Dell precision T5810 which is a lga 2011-3 socket. This is just something I'm playing with and to replace the board due to failure is of little concern (it's cheap) so I'm overclocking and hitting a current limit of 140 watts. I'd like to cut the reported value in half. I have no schematic for the motherboard. I do have schematics for the MOSFETs and pwm controller. And photos top and bottom of the MOSFETs on the board. I would assume the value is being reported by use of a shunt resistor. I'm having trouble testing what resistor or resistors would be in charge of that.
I also found these. They are 6 2.2 ohm resistors directly underneath of the 6 MOSFETs.
Any help would be appreciated.
