Hi all,
I will preface that I am not incredibly experienced in electronics and even less so when it comes to RF interference and noise shielding/filtering so any tips or knowledge is greatly appreciated!
I am trying to design a photodiode circuit that will serve to detect the irradiance of a single uLED light source and provide a fairly high resolution measurement of said light source. This is being done mainly for QC and testing purposes, therefore the measurement needs to be accurate and consistent. The device will also be used in a high power HF field operating at 13.56 MHz which will certainly cause interference and noise that will need to be minimized through filtering.
My vision for the design will feature a detection stage in which the photodiode will output a signal proportional to the detected irradiance. That signal will be amplified (most likely with an op-amp) and then interpreted by an MCU (I'm thinking an Arduino but nothing is set in stone). I was thinking of having low pass filters in between the detection and amplification stage, as well as just before the signal input into the MCU to ensure the DC bias provided by the photodiode is robust and meaningful in terms of the small differences in uLED irradiance I need to detect. I am a little unsure as to the design of these filters and the nuances involved, or even the effectiveness of these filters against open-field radiated interference.
Any help would be appreciated and if one of my assumptions is blatantly incorrect, please correct me. I'm just trying to learn all that I can and see if something like this is even feasible!
Thanks,
Tom
Thanks,
Tom
