So I want to look at a custom housing for 8mm bullets. I would like to design a twist connection rather than plugging straight into an 8mm bullet connector. I am not able to find a single similar design to my concept and I am curious to if there is a reason why my concept wouldn't work. To allow for my custom housing to function the 8AWG power leads would need to be soldering into the bullet plugs at a 90-degree angle. My question would be Is there a functionality or performance issue connecting the leads in such a fashion? Looking around I saw on another forum that there is a reason that PCB's don't have sharp corners. It sounds like there is a potential increase in resistance with a sharp turn. Does that hold true with DC power at this output?
Is there literature I can read about DC power output and plug design that you are aware of?
