Hello all, new member here . . .
I'm currently putting together a coil/transformer winding machine, and stepper motors seem to be the obvious choice
for driving the magnet wire guiding system.
I've searched on google for solutions but I haven't been able to find anything useful yet.
A coil/transformer winder of course needs a motor and a shaft to turn the bobbin, and a magnet wire guiding system which usually
consists of some kind of mechanical system, usually gears to drive the guiding shaft, which in turn is driven from the main shaft,
-much like a feed screw on a metal lathe.
A better solution would be a guiding system that moves the wire guiding mecanism in steps every time the main shaft has completed a full turn,
and in the case of a wire let's say, of 1mm. diameter this step would also be 1 mm.
So, what I'm asking,-is it possible to control a stepper motor driver to do steps by receiving, let's a pulse generated by the rotation
of the main shaft? -The steps would of course need to be varied according to a magnet wire diameter of choice.
All I have found so far are controllers/drivers that need to be programmed.
In this instance this would be both overkill and not practical for my use.
