I was thinking about the member who was starting out experimenting with crystal radio sets. They wanted to learn about the differences between different types of diodes.
See discussion on crystal radio construction here:
https://forum.allaboutcircuits.com/threads/my-shortwave-radio-questions-and-discussion.184242/
So, just for fun I created this simple I-V curve tracer last night in within a couple of hours.
The design is fairly straight forward, a 555-timer circuit and a couple of op-amp ICs, plus an oscilloscope in X-Y mode.
Here is a sequence of photos to demonstrate what to expect.
The horizontal or X-axis is voltage V across the device.
The vertical or Y-axis is device current I.
Hence the slope of the line represents I/V which is 1/R.
Thus, a low resistance will have a steeper slope.
The scale on the X-axis is approximately 1V per division.
Short Circuit
Open Circuit
100-ohm resistor
1000-ohm resistor
From the resistance I-V curves, it is easy to determine that the Y-scale is 5mA/DIV.
Short Circuit
Open Circuit
100-ohm resistor
1000-ohm resistor
