Sourcing replacement insulin pump screen
circnow123
Joined Aug 26, 2021
9
I have an old insulin pump (Animas IR2020), it was manufactured in about 2012 and the OLED screen has now faded to a point where it can not be read easily. It is out of warranty and the manufacturer no longer makes insulin pumps at all. I really want to resurrect this device as nothing on the market compares.
I have dismantled it and removed the screen. I have searched all of the numbers on screen, but can’t find it anywhere.
Here are the numbers:
  • Ribon cable – 095080021A10AR and 10166040816557
  • Back of screen – 102550602R I 8
Printed inside the ribbon cable is a manufacturer “Solomon Systech” and a model number “SSD1339U3”
I looked these up and it seems it is just the controller, not the whole ribbon and screen assembly.
https://www.alldatasheet.com/datasheet-pdf/pdf/150655/ETC1/SSD1339U3.html
Is it possible that this is a custom part made by the pump manufacturer? Or are these screens off-the-shelf?
What would be the best way to find a replacement for this?
Thanks for the help.
takasu
Joined Oct 26, 2022
この有機ELはケンウッドの古い音楽プレーヤーにも使われています。
なので、ジェネリック商品だと思います。
私もこのOLEDを探しています。
DickCappels
Joined Aug 21, 2008
10,180
この有機ELはケンウッドの古い音楽プレーヤーにも使われています。 なので、ジェネリック商品だと思います。 私もこのOLEDを探しています。 注意: これは国際的なフォーラムです。 これからは英語で投稿してください。 ありがとうございました。
@djsfantasi , above in the original post and below is the original text translated to English your message in my words about using English, it is translated to Japanese.
This organic EL is also used in old Kenwood music players.
So I think it's a generic product.
I'm also looking for this OLED.
Please note: This is an international forum. Please post in English from now on. Thank you.
takasu
Joined Oct 26, 2022
特注でパネルを作ってもらいました。交換しました。ただ、バックライトは中央にしか付いていないので純正より悪いです。
takasu
Joined Oct 26, 2022
Although it is written in English, it becomes Japanese without permission.
I had the panel made to order. it is exchanged. However, the backlight is only in the center, so it is worse than the genuine one.
