Hi All. As per the title, I am looking for a modern alternative the the Shinden 2SK1250 Power MOSFET. These are a common point of failure in the power supplies that Sega used for their late 1980s moving arcade machines. The power supplies take a PCM input which controls forward and reverse power of a large DC motor which operates up to 60V DC.
From my experience in repairing these power supplies, failures are usually due to overheating of the 2SK1250, despite there being active cooling systems and an overheat circuit.
Here is a data sheet for the MOSFET;
https://datasheet.octopart.com/2SK1250-Shindengen-datasheet-8316814.pdf
And here is the MOSFET in relation to the power circuit - labelled Q19, Q20, Q21 and Q22
I am wondering if there is a modern, silicon carbide alternative that might be more reliable? Please let me know if you have any suggestions.
