Hello All,
I have a circuit which I have designed for a customer. The circuit contains a lot of white LEDs which are all driven by a single PWM signal. This PWM signal is generated by a microcontroller and passed to a very strong FET and from there to all the LEDS anodes. I can also control each led on/off state using a separate FET on each led cathode to GND.
What powers the FET is the output of a DC/DC converter that outputs 3.3V and can carry up to 4A load (even 5.5A if taken to the limit).
The problem I am facing is that this DC/DC converter will go into hiccup mode when I try to operate many LEDS together even in a low duty cycle mode.
Now before you all jump and say "That's easy - you have overloaded your DC/DC output with too much current" - well, that is not the case.
The overall current taken out of the DC/DC is about 1A (1/4 of its capability). If I reduce the number of LEDS that I want active and increase the duty cycle things work well and I can measure as much as 4.5A on the output of the DC/DC and so it seems that the number of active leds is the cause of the problem and not the current they all draw.
I am attaching a single schematics which I have copied and pasted into it the important parts from my design. In it you can
see the DC/DC circuit, the PWM circuit and a sample of two leds circuit (all other leds circuits are exact duplicates).
BTW, the lower FET of each led (2n7002n) has a resistance of 2ohms.
Any help with solving this would be greatly appreciated.
Mod: re-imaged,
Mod: re-imaged,
