Generate Complementary PWM with dead time.
MrsssSu
Joined Sep 28, 2021
266
I have a similar question to click here. However, in my case i am using ne 555 for logic gate inverter :). I have generated the complementary PWM and it works totally fine. My question is how to add a dead time between the pulses. 1638791091156.png
From click here, people suggests to use an RC network, how do I implement it into this?
Below attached my LT spice for reference :) and try to simulate in LT Spice
34,468
Don't see how to do that with 555s.
Below is the simulation of a non-overlapping clock circuit using two CMOS gate packages:
The non-overlap time is determined by the one R1C2 time constant.
eetech00
Joined Jun 8, 2013
3,961
I have a similar question to click here. However, in my case i am using ne 555 for logic gate inverter :). I have generated the complementary PWM and it works totally fine. My question is how to add a dead time between the pulses. View attachment 254317
Something like this.
Then invert either A or B to get a complimentary output.
MrsssSu
Joined Sep 28, 2021
266
Hi :), can you attach the LT Spice file for this and all the library files for my reference because the LT Spice does not have built in files for these logic gates. Thank you :). And, is the CD410106B and CD4001B be used in high-frequency oscillator circuit and does it oscilllate very high frequency (maybe 100kHz) without its square waveform being distorted?
With your design that has 6 logic gate, does that mean i have to use 6 seperate ic's ?
34,468
Below are the files for the CD4000 logic gates.
The zip files go in the sym folder.
The rise and fall times variy with the supply voltage.
Typical values are shown below:
Operation at 100kHz should still give a good waveform.
Look in the data sheets.
You will see there are multiple logic gates in each package so you need just two packages.
Below is the same functional circuit but constructed with all Schmitt-trigger NAND gates (regular NAND gates can oscillate when seeing the slow rise-time from the RC delay).
It still requires two IC packages but they are now both the same type.
MrsssSu
Joined Sep 28, 2021
266
Hi, Thank you:), where does the 4V Vdd connected to? Is it to power all of the IC chip?
MrsssSu
Joined Sep 28, 2021
266
Yes.
As noted on my schematic the IC power connections are not shown.
Below is a representative package pin layout.
VDD is +power and VSS is ground.
Hi, as note in your schematic,all unused pins are grounded. Is it just a good pratise? I mean unused pins can be grounded or just leave it unconnected because it is almost the same thing right?:)
ericgibbs
Joined Jan 29, 2010
18,872
hi Mrs,
When using CMOS devices, it is common practice to ground all non-used Inputs, [not outputs]
If left unconnected, a high impedance CMOS input can assume a Hi or Lo and can be susceptible to electrical noise.
E
34,468
No, it's not just good practice.
I stated to ground all unused inputs, not all unused pins.
For CMOS circuits, leaving then unconnected is not "almost" the same as grounding them.
CMOS inputs are very high impedance (look like a small capacitor) and can float to a voltage that can cause high internal currents and zap the device.
eetech00
Joined Jun 8, 2013
3,961
Hi
What frequency do you intend to operate the PWM?
The dead-time generator frequency will have to be much faster.
(The CD40106B can be used instead of CD4049B, but use one or the other, not both)
MrsssSu
Joined Sep 28, 2021
266
Hi
Hi, thank you for answering :).You said just use CD40106B for high frequency right? Why in your diagram there is a combination of logic gate. Can all the circuit contain only logic gate from CD40106B(which you said can handle extremely high frequency). Frequency i wish is 1MHz :)
eetech00
Joined Jun 8, 2013
3,961
No. I wouldn't recommend higher than 100khz
No, I didn't say it could handle extremely high frequency. The circuit requires the logic gates I've shown. The dead time delays are obtained using the propagation delays of the inverters instead of RC components.
Then you should use a higher speed logic family like the 74HC/HCT devices.
However, they are limited to supply voltage of 5-6v
MrsssSu
Joined Sep 28, 2021
266
Hi, does the HC or HCT means high frequency?
eetech00
Joined Jun 8, 2013
3,961
HC = High speed CMOS
HCT = High Speed CMOS/TTL compatible.
I don't know your definition of "high frequency".
The max operating frequency varies, but generally, the HC/HCT max operating frequency is about 10-25Mhz Max.
