hand-powered generator to charge phone
Rusty Rifle
Joined Dec 18, 2019
18
Hi all ❤❤
I want to make a generator to charge up my phone ..may you help to find a good circuit to protect my phone from unstable speeds and improve the ripple factor?
I know i can buy one but i want to learn how to make my own
Papabravo
Joined Feb 24, 2006
21,227
How long do you think you can operate this hand charger? Would you be willing to hand crank it for 1 hour? How about 8 hours?
Have you ever seen the museum demonstration of trying to keep a 20 Watt bulb lit with a hand crank generator?
Rusty Rifle
Joined Dec 18, 2019
18
I know it is ridiculous idea to rotate it for a long time but I need to learn about it's circuit design
For example how to make use of not stable sin wave to charge a battery
Papabravo
Joined Feb 24, 2006
21,227
That is a bit vague. Could you elaborate on "not stable sinewave". NOTE: there is a huge difference between time-varying and unstable (not stable). Unstable means "diverges to infinity". I've seen many AC sources that have variations in peak amplitude or frequency, but I have never seen one that diverges to infinity in amplitude or frequency. I suspect that you haven't either. So tell me what exactly you are talking about because your words and phrases, to be charitable, lack precision.
Rusty Rifle
Joined Dec 18, 2019
18
Sorry for my English
I mean suppose we have a not perfect sin wave voltage come out of a hand generator which changes the amplitude and frequency over the time, how can we build a circuit can convert it to DC voltage?
MrSalts
Joined Apr 2, 2020
2,767
You can still rectify it, and stabilize it with a capacitor. The non-sine nature will cause some harmonics that might be a little more difficult to regulate but modern voltage regulators can handle most of what you would put it. What are the constraints of your project?
Papabravo
Joined Feb 24, 2006
21,227
So let us start with some estimates of how much power is required. How much power will it take to charge your phone from 50% up to a full charge?
Once we know that we can estimate the efficiency of the conversion scheme. This will let us know the input power. Once we know the input power we can propose a design for the hand cranked generator that will produce at least that much power. I suppose it would be handy to have access to a machine shop that can cut custom gears for you.
https://www.quora.com/Can-you-hand-crank-a-car-alternator-to-power-other-supplies
