dual bridge rectifier.Voltage? DC Dual as in two motors? Unidirectional or bidirectional? Variable speed or single speed?
Ron
The driver used to drive two 30A dc motor for a small car.A 30 amp motor is no small motor. Dual? What is that? Dual shaft? Dual directional? In general, a motor that big is going to typically have at least an armature winding. It MAY have stator windings as well. If it has stator windings then it is probably not bi-directional. If it has permanent magnets for a stator then it can be run in either direction, based on which way round you hook up power. Positive on one lead (neg on the other) and it will turn in one direction. Reverse the leads, Negative on the one lead (pos on the other) and it will turn in the opposite direction.
Sounds like you're looking for something the size of an automotive fan motor, or bigger. That'll likely have a lot of torque.
At this point we're just guessing. You need to give us a bit more information. If you're looking for a bi-directional motor that can run on 130VDC (Yes, Volts Direct Current) then find an old treadmill motor. They typically have permanent magnet motors and are driven with up to 130 volts DC.
Thanks.Is the for just drives required or does this also require controllers etc?
30 amps at some unknown voltage is a bit much for an RC vehicle, unless it is a serious race car. And I would not ever consider using an arduino to control a car that a person could ride in. There is a place for toys and a car is not that place.So just the drives?
See fig 7 http://tahmidmc.blogspot.com/2013/01/using-high-low-side-driver-ir2110-with.html
Can you utilize a RC drive?
Thanks.So just the drives?
Thanks.30 amps at some unknown voltage is a bit much for an RC vehicle, unless it is a serious race car. And I would not ever consider using an arduino to control a car that a person could ride in. There is a place for toys and a car is not that place.
A "dual bridge rectifier" is not part of a battery drive system. There are bridge controllers, maybe even dual bridge controllers, available, but there is much more to a motor controller than just the final bridge driver assembly.
It would have produced useful answers much sooner if the post included what the rest of the system would consist of, what functions it was supposed to provide, what the supply voltage would be and what te intended power source was. That is to say, let us know about what has already been selected, what it is intended to do, and possibly how big it could be..
by Duane Benson
by Aaron Carman
by Duane Benson
