I am hoping this is the right forum to post this on, although I’m afraid I’m probably woefully under qualified to be here!
I have an old block rocker portable speaker made by Ion:
It’s a very old model, specifically IPA06. When I bought it over 10 years ago, it was pretty good solely because it was loud and ran for 12 hours, something which many smaller units do nowadays anyway but with a more compact higher fidelity package
I wanted to give it some new life and make it useful again so I have modified the drivers and removed unnecessary features such as the 30 pin Apple iPod dock at the top. This process has required gutting the existing circuitry and putting new class D amplifiers.
It used to run on a 6V SLA battery of 7Ah capacity, and contained a 240V transformer with internal charge circuitry. The new circuits run on 12V.
I have been looking at 12V LiFePo4 packs of approx 10Ah, such as this:
https://www.batterymasters.co.uk/li...x-charge-discharge-current-weight-1-2-kg.html
The battery should fit nicely in a new location within the housing and has a high enough rating for the new amplifiers. I have added a DC jack on the rear of the cabinet and have a 12V 6A PSU in an enclosure (typical laptop style brick) so the 240V step down will not be internal anymore.
However: I am not sure how to go about charging a LiFePo4 battery or how to wire the battery so that it’s disconnected from the circuit when charging. I have found conflicting information about charging LiFePo4s, some that says you can charge them with Lead Acid chargers and some that says absolutely not. The logical head on me says not!
Am I right in thinking that to a certain extent, because these batteries have BMSs in them, a lot of the ‘hard’ work is already done- I just need to find some charging circuitry that will apply 12V to the battery and cut off at a certain point?
I was looking at something like this:
https://a.aliexpress.com/_u9aoli
Or this:
https://a.aliexpress.com/_vYqmlK
although I am sure that these are probably a bad idea for several reasons, so I am open to any suggestions to how I can get this circuit running on battery power again.
I can competently solder and put a circuit together, but I’m just not sure what it is that I actually need. Any and all help would be thoroughly appreciated
Or this:
