This suppression diode has broken and when I inquired about it with the German manufacturer, they wanted me to replace the entire solenoid. (High initial cost + packaging + freight from Germany + etc.)
The spec sheet says the coil draws 10W @12v.
Can anybody give a replacement recommendation?
Does it matter which direction it is installed?
Thank You.
Thank You.
