Mystery Circuit ? Any guess what it does?
fieryfire
Joined Feb 14, 2017
150
Hello Guys,
Im stuck with figuring out what the following circuit does. The 3v3A feeds the AVDD of an MCU and 3v3D feeds the IOVDD of the mcu. The 3v3_protect comes externally to introduce to the circuit. is this some protection type circuit? can anybody help me figure out whats going on here?
30,701
U7, TS391 is an analog comparator.
R15 and R6 form a voltage divider. The voltage at C1 would be 10k/(10k + 2k) = 5/6 of the supply voltage.
If the supply voltage is 3V, then 5/6 of 3V is 2.5V.
Z1, LM4040C25Q is a precision 2.5V voltage reference.
Hence the comparator circuit is designed to change state when the supply voltage (+3V3) crosses 3V.
I have not examined the rest of the control circuitry, i.e. the two MOSFETs.
panic mode
Joined Oct 10, 2011
2,715
low output from comparator would turn mosfets on. that causes 3.3V to appear on the +3V3D.
it seem to kill supply to MCU when protected voltage falls below threshold.
AnalogKid
Joined Aug 1, 2013
10,986
This is an undervoltage lockout circuit. The +3V3D output is disabled until the +3V3A input is high enough to enable it.
PROTECT is divided down by R15 and R6, and filtered by C1. Z1 provides a reference voltage to compare against. When PROTECT is high enough, U7pin1 goes low, turning on both halves of Q3.
There is something strange about how Q3 is implemented. That is not the normal back-to-back MOSFET power switch configuration.
ak
fieryfire
Joined Feb 14, 2017
150
Interesting answers. thanks guys. im wondering what does the diode D5 and the double mosfets are for. Couldnt it be done with a single MOSFET?
panic mode
Joined Oct 10, 2011
2,715
not sure what U7 is (and what level) but this is boiled down version. depending on U7 level diode may be needed... most likely U7 and R18 can also be removed.
Irving
Joined Jan 30, 2016
3,843
R15/C1/R6 takes about 3.8mS after 3v3Protect hits 3.3v and for the comparator to turn on Q3a and Q3b.
I originally thought C3/R21 was some form of soft-start, but the values are so low all it seems to do is inject a spike that has no obvious effect.
Here's a simulation with near-equivalent MOSFETs and comparator and a resistive load with some bulk capacitance. Q3b is the main power switch, Q3a seems to do very little...
