This is a reverse polarity circuit as taken from Afrotechmods channel on Youtube.
The 12V battery is charged via a generator charging coil and has a peak voltage of about 45V. I know there should be a regulator in there but on this particular one it doesn't.
The coil sends a pulse rather than constant voltage as it is just a magnet sweeping a stationary coil on every revolution. (every 20milliseconds)
The Load is a microcontroller and associated peripherals all fed from a buck converter, MP1584 rated for 28v input which seems to tolerate the 45v from the charge coil.
Now the battery fully charged is 14.5V so I want a zener above that but is it wise to approach the VGS or reserve some wiggle room? Or is it better to use a zener voltage just above battery?
