How is output power of bldc motor calculated?
Eartian
Joined Sep 16, 2021
29
How is output power of bldc motor calculated? Can we convert any 3 pase induction motor to bldc motor (diy)?
Papabravo
Joined Feb 24, 2006
21,228
The output power of a motor has an upper bound which is the input power. Input power is a function of current and voltage. There will be losses that you can estimate and arrive at an efficiency factor which is then applied to the input power. You can also measure the mechanical power output of a motor by measuring the amount of work done in interval of time.
A key feature of the BLDC motor is the sensing of rotor position to do the communtation at an arbitrary rotational velocity. I don't think that a 3-phase induction motor has this capability, so I would have to answer no without more information.
MrSalts
Joined Apr 2, 2020
2,767
As @Papabravo hinted at, the efficiency (accuracy) of your commutation switching will be key to maximizing output power in a BLDC and, since you don't know how inaccurate you are, there is no reason to calculate the power. Just measure the power by directly connecting a flywheel to the motor and measuring the time to spin the flywheel up to speed. Add some graduation lines to the flywheel with a black market and use a reflection ir sensor to measure the passing of each black line.
Or, if you want to get more complicated, here is a diy dyno project...
https://maker.pro/custom/tutorial/diy-electric-motor-dynamometer-design-principle-and-physics
Eartian
Joined Sep 16, 2021
29
Thank you
Eartian
Joined Sep 16, 2021
29
Thank you
MaxHeadRoom
Joined Jul 18, 2013
28,702
Induction motors have a squirrel cage rotor compared to a BLDC which has a PM version.
Also some method of determining rotor angular position is required.
