Hello everyone, I created this pattern based on other patterns found elsewhere. Unfortunately, it doesn't work as I would like, and I explain why. The initial idea was to create a multi-stage circuit where each stage guaranteed a fixed gain, but this does not happen since when I join the next stage I lose gain in the previous stage. Another problem is the loss of phase linearity. For example, between the input point IN and the output of the first stage A1, I have a drift of -33 ° at 10Mhz. This I would like to avoid even at the cost of changing components as it is an old JFet that can be good for guitars but probably not for this purpose. I have tried other Fet, but the drift problem occurs in an accentuated way in all of them. Maybe I haven't found the right component, or it doesn't exist. The number of stages is theoretically unlimited, this is to say that I would not worry about having 10-15 stages with low gain and high phase linearity if the conditions I will write below are present. So the request for help (if possible) concerns:
1) Gain stabilization (even less than 10 if necessary to limit phase drift) on each stage so that each stage offers and maintains a stable gain at the next stage.
2) limit as much as possible the phase drift described above.
Thank you in advance.
