I AM MAKING A WATER LEVEL INDICATOR AND CONTROLLING SYSTEM. I am confused with the circuit i want two ways of operation
First
The motor should only operate when water level is 30% or down, and whence operate it should stop at 100% level. 2nd it should not operate on 45 60 75 90 or 100 level. Every level indicates an led and 5 volt signal. Also if 45% indicator is on then 30%is also on. 60% on means 30, 45 % also on and further..
I have 5 volt relays with no and nc contacts
I have made this circuit but it is not fruitful as
Because motor starts when the level is below 100 and stops when it is 100.
I have an indication circuit at this time in which I want to add motor controlling circuit
First
