I thought i had to download the free rtos file. because i saw that for avr and other microcontrollers we have to download free rtos files. But I just understood that when we install library for ESP32 , the free rtos library gets installed by defaultI think the activity known as porting has already be done. It is just a matter of using google to find the pieces that you need.
/* Include FreeRTOS APIs and defines */
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "freertos/timers.h"
const int LED_1 = 22; //Pin of the LED_1
const int LED_2 = 25; //Pin of the LED_2
void setup()
Serial.begin(115200);
pinMode(LED_1, OUTPUT);
pinMode(LED_2, OUTPUT);
/*For creating Task, xTaskCreate() API is called in setup function with certain parameters/arguments.*/
xTaskCreate(
Task1, /*Task1 function */
"Task1", /*Task name - Task1*/
1000, /* Task stack, allocated from heap */
NULL, /* No param passed to task function */
1, /* Priority 1*/
NULL); /* Task handle */
xTaskCreate(
Task2, /* Task2 function */
"Task2", /*Task name - Task2*/
1000, /*Task stack, allocated from heap */
2, /* Priority 2*/
void Task1( void * parameter )
Serial.print("Task1 is running on core ");
for(;;)
digitalWrite(LED_1, HIGH);
delay(500);
digitalWrite(LED_1, LOW);
delay(500);
void Task2( void * parameter )
for(;;)
digitalWrite(LED_2, HIGH); // Make LED 2 Pin High
delay(500);
digitalWrite(LED_2, LOW); //Make LED 2 Pin Low
delay(500);
void loop() {}
@Yaakov Thank you! I didn't understand clearly, need more explanation. single core cpu can execute only one task at a time. Task 1 and Task 2 run on the CPU for the amount of time given to them.The point of an RTOS is to have access to the CPU even when there are other things are running. You should try to make something interactive that accepts, say, a button press, while still executing something which needs a lot of CPU. Maybe something that changes the blinking of the LEDs.
The preemptive scheduler is part of the OS. It's not that more than one task executers, it's how the OS manages access to the CPU.@Yaakov Thank you! I didn't understand clearly, need more explanation. single core cpu can execute only one task at a time. Task 1 and Task 2 run on the CPU for the amount of time given to them.
After much thought, I have come to the conclusion that I should first learn how to schedule a task.The preemptive scheduler is part of the OS. It's not that more than one task executers, it's how the OS manages access to the CPU.
https://www.freertos.org/implementation/a00005.html
TTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTT.
22222111111113333333222223333333333333
by Aaron Carman
by Jake Hertz
by Jake Hertz
