Russia says 'software failure' caused thruster misfire at space station
https://www.space.com/space-station-nauka-arrival-thruster-fire-update
Yesterday's unexpected tilting of the International Space Station was caused by a software glitch, according to Russian space agency Roscosmos.
A new Russian module dubbed Nauka arrived at the space station Thursday morning (July 29). In development for more than a decade, Nauka is designed to host science experiments, anchor visiting vehicles and serve as a gateway for spacewalks. However, while the module's arrival appeared to go smoothly, about three hours after docking, the module unexpectedly began firing its thrusters in an incident that caused the space station to tilt from its typical position for about 45 minutes in what engineers call a "loss of attitude control."
"Due to a short-term software failure, a direct command was mistakenly implemented to turn on the module's engines for withdrawal, which led to some modification of the orientation of the complex as a whole," Roscosmos officials wrote in a statement published on Friday (July 30).
o_O :eek:
Wendy
Joined Mar 24, 2008
23,421
Shtuff happens. At least it was not serious enough to cause major damage. I wonder if the space station has onboard thrusters?
That module was cursed from the beginning with problems from the thrusters. My bet would be some safety systems were overwritten to make it work and those hacks were still in place when it fired again. They were lucky it happened early before that module was opened.
