Hello all,
I'm trying to create bldc motor, and have some problem regarding position of hall sensors.
It is 12 pole winding on stator, and 8 pole magnets on rotor, and 3 hall sensors.
But I am not sure where to locate this 3 hall sensors...
i tried locate them on every 120 degrees, but i'm not sure if there is maybe some better positions.
If I use formula Θe = p/2 * Θm, p is number of pols on rotor, Θe is angel of field, Θm is mechanical angle of the shaft, am i right?
So it will be 30degree?
Can someone help me with this issue?
Thanks,
Milan
Thanks,
Milan
