Hi Can anyone offer some advice?
I bought a Korg SP250 on Ebay sold as parts only, no power. When it arrived it was in great condition but sure enough it did not power up. I opened it up and found that the power module was badly damaged. It looked to me like someone had yanked the audio cables out and the force had cracked all the PCB around the jacks. I managed to find a faulty Amp Module which the vendor said had only one working channel. I plugged this in and confirmed no left hand speaker output. However both Audio out channels are working and both left and right channels good on headphone socket.
So looking at the schematic below the most likely culprit would have been IC2, the power amp but it looks like someone has already replaced this judging by the solder on the PCB. I'm waiting on a Scope coming so I can have a proper look, but any thoughts anyone. If I find no signal on pin 7 on IC2 the next candidate would be the equalizer chip IC1. I don't fancy de-soldering that one. Could I be lucky and have a failed capacitor or a dry solder joint?
Any help appreciated.
