One input with a conjugate output IC search
captoro
Joined Jun 21, 2009
207
Anyone know an IC with one input and two conjugate outputs ?
Basically I have a signal and I would like to get the same signal out AND its conjugate signal.
thanks
Ken
34,459
To get the complementary signal of a square-wave you simply run it through an inverter (either a digital inverter gate or a common-emitter transistor stage).
18,566
OK, it seems from the expression you are asking for the signal and it's compliment, That part will be simple if it is a digital square wave, BUT to do it with a single IC we need to know the voltage and the frequency, at least approximately. Is it hertz, megahertz, or gigahertz? And what voltage range?
captoro
Joined Jun 21, 2009
207
[1sterBill2, post: 1651959, member: 512401"]
[/QUOTE]
1khz at 5volts
18,566
A CD4049 can deliver at least 2 sets of waves and their inverted wave and it costs less than a dollar and requires zero programming and it consumes FAR less power. Also it is good up to several megahertz without additional adjustment.
captoro
Joined Jun 21, 2009
207
Isn't the CD4049 an inverter? Yes I can get their invertered but the signal going through the CD4049 will be delayed few clock cycle relative to the input.... Isn't there an IC that can have Q and Qprime as output?
Ian0
Joined Aug 7, 2020
9,835
Assuming it's digital:
CD4041
or
74HC86 - quad exclusive or gates. Two gates, one with the spare input tied low and one with the spare input tied high.
Assuming it's analogue:
THS4531
captoro
Joined Jun 21, 2009
207
CD4041
or
THS4531
CD4041 is what I need, thank you.
Ian0
Joined Aug 7, 2020
9,835
If you look at the datasheet, you'll see that one output has two inverters and the other has a single inverter - in other words, just the same as if you'd used a 4049 or 4069.
If you wanted equal propagation delays, the 74HC86 would have done a better job.
captoro
Joined Jun 21, 2009
207
Right 74HC86 would be better forgot about propagation delays . thank you
18,566
How fast is the clock that the propagation delay of a CD4049 running on 15 volts is several clock cycles?We were never given a frequency specification, I don't think.
