How do we manage to raise Switching Mode PS output current having 3 pin of 2 voltage output and specs :
Input 220V 800 mA
Output
16 V 500 mA
32 V 370 mA
DC voltage was measured correctly by DMM
Need arise because instead of performing DC PS, it and/or its load do stutter, on 16V output, with idle interval around a second as it's being loaded with a RS385 DC motor which runs normally on other PS
Is raising the current output, maybe by replace few capacitors' rating or others' with higher ones, would be the easiest, practical solution and really safe method used commonly, or the SMPS does have some trouble and faulty in some circuit part ? If such above hints it really has some faulty, in which part it'd usually be?
Input 220V 800 mA
Output
16 V 500 mA
32 V 370 mA
