How to export Pspice's plots as a vector file?
7OKER
Joined Jun 25, 2021
6
Hello, I'm a electronics engineering student new to simulation sofwares.
I'm using Orcad's Capture (Pspice) to make simulations.
It only has 'print' option that leads to system print prompt, and I can only print to pdf.
I want to export the plot as a image or vector, like matlab's plot function. How can I do that?
Thanks.
Papabravo
Joined Feb 24, 2006
21,225
Thanks.
Can't you write a filter that reads a PDF file and outputs the desired format?
Irving
Joined Jan 30, 2016
3,887
Thanks.
This may help...
Edit simulation profile, select the Data Collection tab, enable "Save data in the CDSF format".
Rerun your simulation. You'll now find a <simulation_name>.csd file in your SCHEMATIC.<simulation_ name> folder...
The file is the plot data and will look something like.... but I can't tell you how to interpret that - the question seems to have been asked many times but I've not found any answers...
7OKER
Joined Jun 25, 2021
6
This may help...
I will inspect. Thanks.
7OKER
Joined Jun 25, 2021
6
