What are the worst BJTs and/or op-amps you can think of?
Comrade Pingu
Joined Aug 30, 2018
25
I'm working on a voltage controlled amplifier at the moment, and the goal for it is to, no joke, sound as crappy as possible. In general, it's just a long tailed pair of BJTs followed by an op-amp difference amplifier, with the gain controlled by a single BJT current source. If anyone here—especially anyone that's been in engineering for a while—knows a particularly yucky BJT or op-amp, lemme know.
Audioguru again
Joined Oct 21, 2019
6,691
The 741 opamp is 53 years old and has poor performance. It needs a fairly high supply voltage of 10VDC or more, it produces a lot of noise (rumble and hiss) and It has trouble with high level frequencies over 9kHz.
The LM358 dual and LM324 quad opamps produce crossover distortion, produce a lot of noise and have trouble with high level frequencies over 2kHz.
Guitar pedal circuits produce a lot of awful distortion. Some of them use old vacuum tubes, others use old germanium transistors and others use old opamps.
I have heard some compressor circuit that produce very bad sounds because their output levels keep changing.
Ian0
Joined Aug 7, 2020
9,816
My vote goes to the LM358/324 for the worst op-amp, but I don't even think crossover distortion appeals to guitarists seeking that ultimate distorted tone!
and probably the glass-cased OC71 for worst transistor, especially if the paint starts to come off.
To take a slightly different approach, I bet you could make something particularly dreadful-sounding with a CD4007. There's a fair bit about the 4007 on page 8 of this magazine:
https://worldradiohistory.com/UK/Electronics-Today-UK/ETI-Electronic-Circuit-Design-No-1.pdf
I thought I remembered there being a VCA, but it was a VCO, but it's food for thought.
The CMOS inverter with a feedback resistor makes an interesting amplifier, because the gain reduces as the output gets closer to the supply rails.
For some reason they still make the CD4007, I can't imagine why!
DickCappels
Joined Aug 21, 2008
10,179
General Electric 2N107 small signal PNP. They kind of worked. They were production fall-outs but were sold for hobby use in the late 1950's and early 1960's. At U.S. 55¢ cents each, they ate up more than one week's allowance.
Comrade Pingu
Joined Aug 30, 2018
25
Funnily enough, EDP made their Wasp synthesizer with liberal use of the CD4069, another CMOS inverter (see http://www.synfo.nl/servicemanuals/EDP/WASP_SERVICE_MANUAL.pdf), and that sounded awful in the best way possible. You're definitely on to something with that, so I'll look into that after I finish up the more conventional VCA I'm working on—I'll post the schematics once I get a working prototype up and running.
