Why my multimeter keeps showing volts even when I am not testing with it?
jobayer
Joined Nov 4, 2020
6
Hello, I am a beginner in electronics. I have UNI-T UT61A auto ranging multimeter. But I am having somw issues with it. As soon as I turn it on, it starts showing some volts reading in millimeters! But the probes are not connected with each another nor I am testing anything with it.
And slowly it starts reducing the voltage. But it never stops at zero when the range is in millivolts which is the most surprising thing to me.. Because yeah when we turn it on, there might be some voltage going through it. But why it will never be stable! It stables at zero when I manually set the range to volts, not millivolts.
What might be explanations or possible reasons??
Again I am sorry if it is a too silly question. As I said I am a beginner. So excuse me any way. Also thanks in advance.
rsjsouza
Joined Apr 21, 2014
383
This is one of the most asked questions for the new multimeter users, so you are not alone in your amazement.
The reason is that around us there are many sources of electrical and electromagnetic noise (Radio/TV, fluorescent lightbulbs, switching power supplies, Wi-Fi, Bluetooth, etc.) and these are picked up by sensitive equipment such as a multimeter. The leads and the jacks act as antennas that act as receiver of this energy, which is then measured and shown in its display.
Notice the magnitude of these voltages is quite small, as you pointed out (mV).
If the probes are shorted, you should read zero or somewhere close to it.
jobayer
Joined Nov 4, 2020
6
Yes, when I short the probes, it stables at 2.1 mV.
Also thanks for your answer. Your answer is very much logical!
BobaMosfet
Joined Jul 1, 2009
2,113
This is normal- with any meter. This is why you touch the probes together to zero (completes a circuit) before you use it.
MaxHeadRoom
Joined Jul 18, 2013
28,702
The old moving coil (Avo) meters were not so prone as the higher impedance electronic versions are.
BTW, a good practice to get into with any meter is to test the leads first on the ohms scale, particularly before measuring HV DC & AC.
rsjsouza
Joined Apr 21, 2014
383
@MrChips , the fuses on modern DMMs are not in the same path as the V/Ω, so this would not necessarily tell anything about the status of the fuses. Even the ones that have V/Ω/mA/μA in the same input.
You could potentially put the meter in ohms and then insert the red probe into the A/mA/μA jack to see if its fuse is working (although some meters do isolate these inputs as well).
30,824
You are correct.
In our student lab I had to test every DMM at the end of each lab because a fuse would be blown and the next group of students would not realize it. I made a simple tester with an LED, resistor, and battery for this specific task.
Thanks for correcting me and reminding me.
rsjsouza
Joined Apr 21, 2014
383
These "fit for purpose" test jigs are always useful - I lost count of how many I designed and built in the past.
Audioguru again
Joined Oct 21, 2019
6,710
The DMM is set to measure DC, not AC and it can never show 0VDC even with its leads shorted so it has a defect or it is so cheap that is how it is made.
My Fluke multimeter measures 0.000VDC even when the autorange sets it to measure millivolts and the leads are antennas.
Set to AC it shows up to 50mVAC interference when the leads are antennas, but when the leads are shorted together it quickly shows 1mVAC then very slowly drops to 0.2mVAC and less.
bloguetronica
Joined Apr 27, 2007
1,541
I've seen many multimeters do that, especially in the mV scale, which typically presents an even higher impedance and thus it is more sensitive. Nothing to worry about.
Both of my Aneng multimeters tend to drift when floating, but they always read correctly nevertheless. The values they tend to drift to are in the vicinity of 100mV. I suspect that they pickup voltage from their own circuit. This kind of drift is typical of circuits that:
- Are in a PCB;
- Have a very high input impedance;
- Don't have a guard ring around the sensitive traces.
The above conditions will suffice in order to pick up readings from adjacent traces, internally.
