hi everyone, I can't understand in this datasheet, the voltage range that the output signal can have in the headphone jack. (HPOUTL, HPOUTR)
Perhaps?Hello there! You are going to have to be more specific, this is an assumption but it is a beginning.
Maybe you are referring too.Table 45 Volume Control for HPOUTL and HPOUTR . Register Address, bit7, Default bit0."Headphone Output Volume Update Writing a 1 to this bit will update HPOUTL and HPOUTR volumes simultaneously."
Or!
2278 lines (1883 sloc) 61.9 KB
Linux-3.8.13 CODECS
wm8904.c -- WM8904 ALSA SoC Audio driver
* Copyright 2009-12 Wolfson Microelectronics plc
* Author: Mark Brown <broonie@opensource.wolfsonmicro.com>
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License version 2 as
* published by the Free Software Foundation.
I hope this helps.If not please do not hesitate to ask!
by Jake Hertz
by Jake Hertz
by Aaron Carman
by Jake Hertz
