New to PCB Design and layout. While routing bypass caps, I instinctively give each bypass cap its own via to the ground plane. What would be the disadvantages of having two (or more) bypass caps share the same ground via?
I suspect the consequences are more apparent in high-speed and/or high power designs, but in low-power, low-speed designs, what are the disadvantages of doing this?
