Hello!
Channel Equalizers tries to restore distorted received signals back into the original message through filtering based on the estimated channel parameters. But this is an estimate. If I increase the number of observations, then it gets a better estimate. Is there anyway to improve the accuracy further?
I am debating with myself if I can decrease the processing and receiver delay it can improve the accuracy since there are less uncertainties for error. I was also thinking if the length of the equalizer is as short as possible then the filter won't be able to filter what it shouldn't be filtering (the original message).
I want to make sure my ideas are correct.
Thank you very much in advance!
