I have a Kustom 200 watt guitar amplifier head, it's several years old. When I plugged it in to test a new set of speakers I had built, it seemed to power on, but I couldn't get any sound out of it. (lights came on, all the channels seemed to be selecting properly, etc..) I opened it up, and found that one of the capacitors on the power board had completely fallen off the board. The positive pole wire was broken off to about 1/32 of an inch long, and the negative wire had apparently come unsoldered from the board. These are Aluminum Electrolytic Capacitors, 6800uf, 63V. I also noticed that on the other side of the board, from the positive connection of this cap, the solder line appears to be interrupted/broken in a spot, but it looks like it was that way from the factory. Sooo...the questions I have are; 1) What could make the capacitor fall off the board like this, and 2) When I replace the capacitors, should I also reconnect the solder line that appears to be broken by soldering it together. I've included pictures of the capacitor with the broken pole wire, the board showing the broken solder line, and also the piece on the board that this line goes to. The solder connection also goes to other components in the other direction, but this is the only thing it goes to where the line is broken. I'm not sure what this item on the board is either, so any help with that would be appreciated also!
Thanks for any help anyone can give me with this!
