Hello
I would like to use a simple full bridge rectifier circuit without any filtering to power a LED work light. These work fine with no flickering when I bench test it with a 240vac to 24vac transformer.
In our DB electrical box, we have a1000V to 24V transformer. The secondary 24V is grounded so I believe I would have to have the DC output floating.
The wires of the LED light are isolated from the LED body. The LED is mounted on our metal skid.
I believe the CB would trip (and fuses might blow) if one of the wires touched the skid frame.
I would just like to make sure the circuit is safe.
PS My 240V to 12VDC is running near max amps so I cannot tap into this.
Thank you
Thank you
