I'm working on a little project to power some old Airbus overhead lights using LEDs and the built in push buttons, however I'm a little stuck on the solution for this.
Essentially the unit has momentary push buttons for toggling the lights on and off. I intend to power some LEDs and toggle them on and off using the existing buttons, but I dont know the right approach.
I tried thinking of using an S/R latch to toggle the LEDs on or off, however connecting the S and R pins to the button at the same time didnt really work, I tried putting some gates in between but that just made things worse!
There must be a simple solution to toggle an output based on pressing momentary push buttons but I'm not aware whats out there. Is there a simple IC or component that can do this?
